How are injector fault actually detected by the DME?
    Are knock sensors involved in the detection of injector errors?
    I've:
    Replaced injector six with a new injector
    Swapped the coil packs
    I guess it must be the wiring or the DME driver transistor?
    Click image for larger version  Name:	image.png Views:	0 Size:	43.9 KB ID:	363168​​
    DME can detect the faulty open circuit as it senses zero current flow through the a sense resistor.
    i would check the connection and wires from Dme to injector
