I have been having this issue recently when my car hits half tank or little below half the car will shake hard like almost misfire and it shuts off, and when I fill it up it’s normal, I replaced the the fuel filter but I’m thinking it’s maybe the fuel pump or the float?
E46 fueling issue?
Use INPA or the cluster secrete display mode to show the L and R tanks fuel volume when the total is less than 3/4, as this doesn't help with a full tank. If L is more than R then the issue is a worn weak fuel pump running slow, or a leaking pumping as Cubieman said.Originally posted by BinBuilt View PostI have been having this issue recently when my car hits half tank or little below half the car will shake hard like almost misfire and it shuts off, and when I fill it up it’s normal, I replaced the the fuel filter but I’m thinking it’s maybe the fuel pump or the float?
