Originally posted by eacmen
View Post
SMG II Pentosine Replacement
The SMG system reminds me of the ABS. The pump seems to be attached to an ABS module just programmed to actuate at different pressure for different periods of time. They use brake lines and a reservoir. Instead of having a master cylinder, there's a pump electronically controlled. Because of this, I believe you must actually drain the lines to get the fluid out. That's how it has to happen on a braking system. Instead of pushing a pedal, which doesn't exist, you have to just drain the lines. I have no idea how the system actually bleeds itself. I would think it uses the solenoids inside to flow fluid around somehow. Maybe it creates vacuums in the right areas.This is my Unbuild Journal and why we need an oil thread
This is how you do it (just let chrome translate to english):
https://burkhart-engineering.com/en/...wechsel-smg-2/3.91 | CMP Subframe & RTAB Bushings | SMG (Relocated & Rebuilt) | ESS Gen 3 Supercharger | Redish | Beisan | GC Coilovers & ARCAs | Imola Interior | RE Rasp | RE Diablo | Storm Motorwerks Paddles | Will ZCPM3 Shift Knob | Apex ARC-8 19x9, 19x9.5 | Sony XAV-AX5000 | BAVSOUND | CSL & 255 SMG Upgrades | Tiag | Vert w/Hardtop
Thats a great link. Thank you!Originally posted by oceansize View PostThis is how you do it (just let chrome translate to english):
