Mating engine + transmission
    Wrapping up an engine rebuild. Changed the clutch, flywheel, throw out and pilot bearings. Now stuck on the last step!
    I cant for the life of me mate the transmission to the engine. It seems like the angle for the pilot bearing and input shaft must be perfect for it to slide in. It's been extremely difficult doing this with the engine on an engine hoist and transmission on a jack. Lubricated all surfaces with a dry moly lithium grease.
    Has anyone dealt with this before? This is the only thing in the way of firing up the car after a rebuild
    I had a similar problem under the same circumstances. I had to set the engine down on a pallet so it was stable enough to sort of wiggle the transmission and get it seated in the pilot bearing. I then got the bolts started and cinched it down.
    2003 Carbon Black - Karbonious CSL intake, CSL DME w/MAP, SSV1 headers/Catted Section1/63.5mm Section2, Shrick 280/272 cams, Lang Racing Stage 1 cylinder head, Eibach Pro Street S Coilovers (500#F/600#R), GC Sways, AutoSolutions SSK, Motorsport 3.91 rear diff, BBS RGR wheels, Streamline CSL front bumper
      Did you remove headers before setting it down? Headers are the lowest point when setting it down and I'm fearful they'll bend
        I didn't. They wont bend. They just direct it to sit on the oil pan. They will be fine.
