Rebuild Gurus,
What is the proper procedure for a first start following a rebuild? From my understanding, the goal is to build up oil pressure before turning the engine over. I turned over the key a few times with spark plugs out and didn't hear any priming of any sort, likely because the oil pump is mechanically driven. I just want to be sure before I seize any bearings and undo 3 months of work
Just some details, spark plugs out, all harnesses connected, O2 sensors not connect, no coolant, no belts, etc.
