Originally posted by eacmen
Second track session the SMG failed. No matter what I tried the unit would no longer bleed. Even though it was a unit rebuilt with MLR seals it seems to have failed. I swapped in the original SMG pump that came with the car and it started working as normal.
So TL
R if you hear buzzing vibration sounds that happen even if the engine isn't running while shifting gears or holding it in neutral. Its the SMG pump on its way out.
