Background: OEM calipers with track pads. Track event in March, pedal started to engage lower. But fluid was ok, and brakes continued to work. Finished the weekend but went easy on the brakes. After that event installed brass caliper guide bushings and SS brake lines. Bled 1.5 liters of SRF through the whole system. Same pedal travel.
Curious if others experience the same brake pedal travel that I do. When the engine is off I can pump the brake pedal and it is rock hard. Maybe 1/2 inch of travel before it gets hard. I can stand on it and it doesn't move.
But if I keep the pressure on the brake pedal, start the engine, the pedal sinks *significantly* approximately 1/2 inch below the throttle. And my brake engagement point is also pretty far. The brakes work and there is engagement but the pedal travel just seems long.
The front pads had some slight pad taper to them which I am hoping the brass guides will fix. Havent had time to take the car out and wail on them to get the front pads flat. Could a tapered pad cause long travel?
