Originally posted by 10figs
View Post
CSL Airbox Ducting with Standard M3 Bumper
I agree with this. It'll be nice and neat.Originally posted by Slideways View Post
Best way to do this a get good air flow to the snorkel is to get an Eventuri style scoop and connect a 3" brake duct tubing from the snorkel to the top of the scoop. The secondary feed can be blocked off with a 3D printed plug which Karbonius might have available.
If you think about it, this will flow basically zero air unless you use something like the Eventuri scoop as well. The factory system is under vacuum so can pull air up from the duct without it. Just sticking the CSL snorkel end into the hose won’t pull up any air because of the huge opening to the rest of the engine bay — needs a ram air effect as well for any air flow to happen.
Thanks appreciate the feedback here super helpful.Originally posted by repoman89 View PostIf you think about it, this will flow basically zero air unless you use something like the Eventuri scoop as well. The factory system is under vacuum so can pull air up from the duct without it. Just sticking the CSL snorkel end into the hose won’t pull up any air because of the huge opening to the rest of the engine bay — needs a ram air effect as well for any air flow to happen.
