Following completion of some engine work (head gasket creating misfire like issues, and fresh rod bearings), some loss of power has returned to plague my car. When I was having the head gasket issue (compression bleeding into other cylinders) there was a distinct loss of power acting like a misfire. I noticed this through things like engaging the clutch in 1st gear, where the car would jutter, squeek, and sometimes stall out. Around the same time (fall 2019), I completed some engine work where I disconnected the battery, coils, spark plugs and the issue went away for a few driving cycles.
Following the engine rebuild, the car was incredibly ALIVE, it felt like the sport mode button was engaged at all times. But again, following some driving cycles, so within 130 miles of driving the car again, the loss of power returned. It feels like when you turn the sport mode button off, except the stock driving mode was sport mode. I can easily feel the loss of power now because of how alive the car felt the 2 days prior to the loss following the rebuild.
The engine runs silky smooth now, no check engine lights, no issues, idle is perfect.Things I've recently done that would effect the power:
- coils (<6,000 miles)
- sparks (<6,000 miles)
- New fuel filter
- Vanos full rebuild (helical gears on sweet spots)
- Fresh oil
- Fresh gaskets
- Cleaned cam sensors
- Fresh oil & coolant
- All valve shims within spec
- Fuel pressure @ 5/5.5 BAR
- Fresh air filter
- MAF Cleaned
- Compression test following new head gasket - GOOD
- Header to engine block gaskets new (no leaks - all bolts tightened on engine stand)
- Head to section 1 gaskets - GOOD
