Rear axle rebuild/replacement?
    Originally posted by thegenius46m View Post
    Stumbled upon this while repacking my inner CVs with the gkn boot kit and it is great news that the Porsche CVs Are a direct fit for the inners, but unless anyone has found a solution for the outers I am questioning what the purpose of just replacing one side of the axle is when obviously the outer do develop play over a lifespan And essentially, you’re just rebuilding half of the axle.
    Now after doing this job, I was seriously, considering ordering the inners to do at a waiter time, but if there is no way to rebuild the outer joints, I’m having a hard time justifying doing all the work to only improve the axle maybe 50% instead of a full refresh because greasing alone is not a rebuild. It is just a “repack” which obviously does not reduce any play in the joint it just fills it with grease.
    Curious, if anyone can try in if they found a solution to date?
    Currently axles are almost $1000 each side from BMW for brand new, which at that price you might as well go aftermarket to some upgraded option like driveshaft shop.
    It would just makes sense if your inners have play and outers are fine, that saves you from spending 1000 bucks for a new axle shaft when only one side is bad. If the outers are play free you just repack to make them last longer. If you service the shafts let’s say every 50-60k miles I don’t see why you would need to ever change or rebuild them. Issue with the inners is that the exhaust runs close to them degrading the grease and over time that causes them to develop play.
    it makes sense to repack only if you have no play, and to rebuild the inners if those are the bad ones but outers are fine.
    lucky e46 m3 owners that only the driver side is exposed to hot exhaust, us Z4 owners have that on bot sides.
      The outer boot can be replaced. It has been awhile and was a greasy nightmare that I have mostly forgotten. I think you have to angle the CV so that you can get one of the ball bearings out and then work your way around. I just remember it being an exercise of frustration trying to handle greased up balls...lol...and getting the CV back together.
      Should do the outers but the inner takes a lot more punishment from the exhaust heat.
        The outer boot can be replaced, but to remove the CV you have to remove the outer cap, you can't get the ball bearings out with it on. The outer cap is a crimp fit with an o ring, so you will have to recrimp it and possibly use epoxy to keep it from leaking when reconstructed. Since they don't sell outer CV's, there's no point removing the cap. If you have a pitted outer CV, grab another used OEM axle and rebuild that instead.
        Like has been mentioned, it is the inner CV's that become pitted due to heat and old grease, the outers seem pretty robust. Just inspect and repack with new boots, and put in new inner cv's if needed.
          Like has been mentioned, it is the inner CV's that become pitted due to heat and old grease, the outers seem pretty robust. Just inspect and repack with new boots and put in new inner cv's if needed.
          Did I end up removing the inner and then slide the outer boot over the axle? Crap, I can't recall probably because it was such a shit show...
          That might be the case because I didn't want to damage the trigger ring for the wheel speed sensor. I just changed the rear wheel speed sensors yesterday and the trigger rings were goldish/silver which kind of makes the think I replaced them? I can't remember...lol
            I do not have a 3D printer, but more interested in getting one lately. What type/shape of tool are you imagining?
            I wish these were still available, even had orings..
            Click image for larger version  Name:	Screenshot_20250907_202549_Chrome.jpg Views:	399 Size:	40.7 KB ID:	324160 Click image for larger version  Name:	Screenshot_20250907_202558_Chrome.jpg Views:	390 Size:	43.4 KB ID:	324161
            For the love of god someone please make these. Thank you CrookedCommie for the write up. Couldn't have done it without your helpful guide. What a pita....
              Glad it helped.
              I ran the rebuilt axles for a DE event. They did spit out some of the extra grease, talking with my endurance racing buddies, that maybe normal. Next time I do this I think I may try and weight the amount of grease going in so as not to overpack, if memory is right it's 80 grams per CV. I would also reuse the old BMW grease caps, as they seem tighter than the GKN ones that came with the CV kit. I also had the inner CV to diff flange bolts loosen up, BMW has those spec'ed at 56 ft lbs, I tightened them up to 80 ft lbs. I reused those bolts as a set of new ones are $$$.
              Regarding that outer Turner kit, this forum member works at ECS and found that they still have the prints for them, but haven't gotten an update yet. Maybe worth reaching out to them again.
              This is a long shot as this product hasn't been made for a while. Rebuilding the outer CV's means likely ruining the "cups" that seal everything up so this kit looks great, wish they still made it. If anyone has this product and doesn't want it I would sure like to give it a try! https://www.turnermotorsport.com/p
                Some more info regarding the axle rebuild:
                The outer E46M Vaico boot kit came with the correct clamps, but you will have to trick the big 68mm on, use a small hobby screwdriver through the slots to lock it back onto the tab. The inner boot kit came with too small of a clamp for the small side of the boot, see below for the correct one.
                To clean the outside CV, I got as much of the old grease out using shop towels and letting it drip out, then used a bucket of gasoline to clean the rest out, by basically jerking the axle in and out of the CV. Use compressed air to blow out the gasoline and grease. Repeat until clean, inspect for any pitting, as a final measure I used brake cleaner to make sure it ran clean out, then dry it out with the compressor. Note that the axles are hollow and there may be old grease in the middle of them. Repack using Redline CV2 and work it back in. Grease the axle shaft and sneak the new boot in through the inner CV side.
                For the inner CV grease caps, I used the GKN ones that came with the E46M kit, it is easiest to use a rubber mallet to get them started, and the edges of an anvil and a 2x4 block with a hammer to press them all the way back into place evenly.
                Overall this cost me roughly $300 in parts because I had to get two new inner CV's. E46M axles are still available new in Europe but go for $1500+ This is a motherfucker of a job but well worth it, you do not want to miss out on a track or race event due to a bad axle. I will be wrapping the exhaust that goes over the driver side axle to keep it from cooking the grease.
                I will update the thread once I get the race car on the track and have ran the axles through the ringer, I have a spare set of shafts that I will rebuild using this method as backups. ​
                Parts I used:
                2x Outer boots
                2x Inner boots
                2x Inner CV's
                One jar Redline CV2 should be enough to do two axles:
                If you use the E46M GKN boot kit, it comes with too small inner clamp, use this one:
                https://hcl-clamping.com/products/ea...-34-40mm-304ss
                I know this is an older post but thank you for this info, I also ordered the GKN kit and saw it mentioned in the reviews that the small clamps were too small, and what I had on hand didn't end up fitting either. I love it when a purpose built kit ends up not having the right parts, but at least with your reference I can get the job done.
                Also great to know I should re-use the BMW caps, I'll try and test fit both to see if I can notice a difference.
                For the amount of grease, like you mentioned the packets come with 80g each.
