Originally posted by Obioban
Vincebar vs. CMP Topside Reinforcement
Originally posted by ZHPizza View Post
There's also these solid aluminum mounts that have removable spacers to account for plates. I have them in the garage waiting to go back in with the subframe.
https://store.partsshopmax.com/shop/...is/E36SFR.html
OMG truth. I bought the cheapest rivet gun I could find at Harbour Freight, my friend and I took turns so the other could rest. If you have some scrap pipe laying around you could put those over the handles for more leverage.
Another thing I would definitely do is get an epoxy gun and a few mixing tubes, I was able to borrow one from work. The tubes mix the epoxy in the exact ratio needed and are much cleaner than you messing about squeezing it out by hand onto a plate and mixing it with a popsicle.
I also ordered a 3M epoxy gun from eBay that came with a bunch of extra mixer tubes, which are also a definite must for this project.
Originally posted by Obioban View Post^I agree with most of the above, but I'd skip the power flexsubframe bushings. Since 2017 isn't enough time to prove them out, and before that they had a 17 year history of failure. Beyond that, what are you gaining over the stock subframe bushings, which have a pretty proven out 200,000 mile service life.
IMO there's only two subframe bushing options that make sense:
1) stock
2) CMP solid (which raise the subframe, correctly the suspension geometry lost from lowering the car and/or adding reenforcement plates).
Configurable solid bushing set has the ability to correct the control arm angle and CV joint angle on lowered cars by raising the subframe up against the
1) stock
Imo the best set up for a road car is:- Redish Motorsport plates
- These are high quality and are also tried and tested. Redish themselves have not had any failures since installing these on cars since 2011.
- Vincebar + Gussets
- The bar itself ties in the chassis rails and so relieves load from the RACP
- The gussets address the front internal mig welds behind the rear bench which are generally the first point of failure (but are often missed by garages who offer these repairs)
- Both bar and gussets are bolted to the subframe itself which ensures all 4 points are reinforced
- The set up is not visible and so does not intrude boot space
- The set up has been tried and tested since 2016 with no reported failures.
- Powerflex Yellow/Purple Subframe Bushes
- Recommended by Redish Motorsport who as previously stated have not had any failures
- The durometer of these bushes are spot on (70A/80A). They absorb the torque from the diff without transmitting it into the floor of the car
- If the bushes are too soft then overtime this will exacerbate movement on the mounting points leading to cracking (like the stock ones do), however if they are too hard, you could also be reducing the life of the RACP as the floor is no longer cushioned by the likes of solid bushings.
- Note there were reports of Powerflex Yellow Gen 1 bushes mushrooming, however there have been no reports of this since they were revised in 2017.
- OE (stock) Differential Bushes
- These bushes do not transmit any extra NVH into the cabin unlike polybushes and are good for 80-100,000 miles
- Note there are 3 bushes (and bolts) which should be replaced - (2 rears and 1 front). The rear bushes cannot be bought separately from BMW and so must be bought with the rear diff cover. If not done already, it may also be worth uprating your rear bolts as they were revised by BMW post-production following a PuMA case in 2007.
I used this to install about 100 3/16" rivets with ease. It crapped out after that but I'm happy with the performance for the price. I'll order another one and be a little more cautious with it.
Someone in Orlando pls help install vincebar lol
Originally posted by Johnvu View PostBar Epoxied and Riveted in place. **One huge suggestion is to get a pneumatic or assisted rivet gun. I almost crapped my pants getting those larger side rivets in place lol.
Originally posted by Tones View PostWhat's vinces face book
Sent from my Pixel 3 XL using Tapatalk
I did it myself in my garage. I used a bunch of images from Vince's facebook and other's that have done this to guide me through the process. As timmo said above, make sure you cover the interior of the car before grinding and whatnot.
I used some moving blankets from Harbor freight to make sure everything was properly covered while doing the grinding. The last thing I wanted was ruined interior. Here are some images throughout the process:
This was when I was spraying all of the exposed areas with the Steel Grey matching paint. However, I used these types of moving blankets to cover my interior during grinding as well.
What it looked like after reinstalling the interior pieces. I love that it is back to stock and not noticeable!
Originally posted by LSBNick View Post
Did you do this yourself or have a shop do it for you?
It's not too bad to do if you're handy with other DIY work on your car, I did it with a friend over a long weekend.
Wait are we back to adehisve epoxy for the plates is okay? I'm out here in rural Hawaii and I don't trust any ones Craftmanship to be honest. Everyone just phones everything in here. So epoxy be great and I can do it my self.
Mike
