Swapping Diff Cover in Situ
    So the 2 rear diff bolts that hold the diff to the subframe are 50 ft lb then? Having trouble finding this one on paper. I see newtis says 20nm + 90°.
    https://www.newtis.info/tisv2/a/en/e...-drive/5XGnMyr
    I believe I saw it confirmed somewhere on the old forum that for the thread pitch and grade on those bolts, 15 lb ft and 90 degrees gets you to right around 50 lb ft.
    Youtube DIYs and more
      Just finished refreshing rear diff bushings (2 in cover) with e36 M3 diff bushings and new castrol oil today.
      Removed 2 upper rear bolts, all cover bolts. The very top 2 "hidden" cover bolts required lowering the rear of the diff to extract the bolts. Cover came off easily. I didn't remove the sway bar brackets, which made those top 2 cover bolts a little harder to screw out by hand, but doable.
      Glad it's over. Now that front and rear diff mounts have been refreshed, hope not to touch the diff again, except for oil changes.
      Sent from my SM-G960U using Tapatalk
        I just ordered this from BMW and it came in a syringe lol
        Anyone know what dispenser to use ?
          That is the dispenser and is what i used.
          3.91 | CMP Subframe & RTAB Bushings | SMG (Relocated & Rebuilt) | ESS Gen 3 Supercharger | Redish | Beisan | GC Coilovers & ARCAs | Imola Interior | RE Rasp | RE Diablo | Storm Motorwerks Paddles | Will ZCPM3 Shift Knob | Apex ARC-8 19x9, 19x9.5 | Sony XAV-AX5000 | BAVSOUND | CSL & 255 SMG Upgrades | Tiag | Vert w/Hardtop
