What mods would you do on a $10k budget?
  • bassel_sy
    if maintenance is up to date id go
    1.Coilovers
    2.Brakes
    3.Set of PS4's
  • cdnabroad
    Also , If you do the valve timing, spark plugs and ignition coils you will get some Hps back that you didn't know you had lost. I definitely noticed the difference when I got my car back.
  • Obioban
    Those seats look good but I'm afraid I'll miss the lumbar support and squishy leather of the stock seats. Then again, you did say the Nogaro seats have adjustable lumbar support...🤔
    Yep— I have adjustable lumbar and squishy leather :P
  • MTiz
    Streetable buckets, you say? I only know of one sold in the USA:
    https://nam3forum.com/forums/forum/m...ck-bucket-seat
  • Obioban
    Originally posted by Tigerbimmer View Post
    Ugh... I have to agree. Was looking at power mods next but now my focus is quality streetable buckets to replace the stock seats. Sliding all over the stockers since suspension overhaul and takes away from the experience.
    This is installed in my e46, but it really applies to all BMWs equally, so thought I'd post it here, as well. I am just going to start with pictures, because I know everyone is going to skip to that either way. Please read on, after, as there are a ton of very specific reason why I think this seat is THE best seat on the
  • Tigerbimmer
    power is the least meaningful upgrade, imo. No matter how much you have, it feels “normal” after a couple weeks. If you DDed a Bugatti, I’m pretty sure it would feel slow after a couple months.
  • Obioban
    If it hasn’t already been done, in this order:
    vince bar (subframe)
    beisan vanos downs and valve adjustment
    replace all fluids with new OE fluids
    entire cooling system
    every bushings/bearing/ball joint in the suspension
    bluebus
    TCK S/As
    Light weight 18” wheels with good tires (Michelin non all seasons)
    replace any interior components that are looking worn/tired
  • oceansize
    Here is the type of car you should be looking for. 106k with VANOS done, new OEM clutch flywheel, RACP reinforced with redish plates, and lots of maintenance. Bearings done at 20k as part of recall. Very well taken care of car that frees up cash for other stuff.
  • cdnabroad
    Having just been faced with some of these decisions over the past few months, this is what I did, which is a combo of some of the above suggestions and a lot of reading on the old M3forum
    A) Maintenance = Inspection II and a full Beisan VANOS upgrade. My thought process here was, all the mods in the world on a bad starting platform = a bad end product.
    B) I chose the suspension and brakes to do as initial mods = All bushings, mounts upgraded [DINAN monoballs, Tower Brace, Koni/Eibach Combo] For the brakes I went to an entry CSL style BBK with new lines [this will still cost you 1K plus in parts] The final thought process here was that the car is pretty fast as it is and is only going to go so much faster without a turbo and having a lot more control over that speed seemed like a good place to start.
    I'm really happy with the end result and will try and do a longer write up as to some of the options considered and decisions made during the month long process. The care drives better than new and while the maintenance and mods I chose were not cheap [Parts were around 4K alone] the piece of mine of knowing the car is going to be good for the next 50K was worth it.
  • mainstreamer00
    Discussion at this point. Still a few months away from entering the market.
    Nice.
    If you have the luxury of time, really hold out for:
    a) a car without deferred maintenance. that's one way to really eat up your 10K.
    b) a car with many/some of your preferred mods.
    Lots out there if you're wiling to travel. Probably more over the coming months unfortunately. Keep us posted!
  • MTiz
    Originally posted by mainstreamer00 View Post
    Is this for discussion only, or are you looking for some gameplan opinions?
  • MTiz
    Originally posted by Bostonbruck View Post
    100% without a doubt I would make sure that the cooling system, Vanos, subframe, and rod bearings have been taken care of, along with new tires, suspension bushings, fluids, and filters. That will run you about $4-10k depending if you do it yourself or not. If maintenance is up to date, continue on with the mods.
    Do a few mods and see how you like them. You can always add more. Before you pick out some mods, do a little research about them, it can tell you a lot. Saving some of the money would not be a bad idea, as you may have some unexpected problems come up in the future.
    I had spec'd out wheels, tires, suspension (without bushings), headers, and a muffler and I was already over $5k. It really got me thinking on what was important and what I could live without. At the end of the day I really just want a clean (and reliable) OEM+ build that sounds good and has good fitment is more than enough for me.
    This also reinforces the fact that I definitely need to buy a vehicle with preventative maintenance already completed (and if any, quality mods) once I do enter the market for one of these vehicles.
  • mainstreamer00
    Originally posted by sina View Post
    Just curious, how much is there to gain with these mods if you're still on US headers? It feels like everyone that has an airbox did headers first. For me the first big mod would 100% be CSL airbox, couldn't care less if there are no gains, just need that sound 🤤. And then maybe later headers to actually take advantage of the airbox.
    100% you need to ditch the US-spec headers.
    Get yourself a set of euro headers and some kind of resonated section 1 - tangible difference. An airbox would not be worth it without at least this mod IMO, even from a tuning perspective alone.
    An interesting "cheap" mod I did that totally transformed the car was a quicker steering rack. I did the .712 yellow tag, but nearly anything is better than stock.
  • COVID-19
    I mean you can skip the cams and do full exhaust, CSL intake and tune then the rest on maintenance and whatever is left on on exterior or interior bits. I like my m3 NA.
  • sina
    Cams, CSL airbox and tune. Or wait and find a used SC.
