Originally posted by sapote
(crank at tdc with cam lobes pointing at each other, crank locking pin also in place)
Fully retard intake and exhaust camshafts.
For each camshaft, place open wrench (24mm combo wrench) on camshaft hex between cylinders 1 & 2 and turn camshaft counter clockwise to adjustment end position.
Note: Camshaft rotation is most effective when standing at exhaust side of car.
Note: Rock camshaft back and forth to release bind and allow rotation.
Note: Camshafts should already be in fully retarded position.
then the instruction tells you to put the bridge and make sure it's aligned.
so you only need to turn the exhaust cam ccw? should I rock it cw and ccw to release any bind and get the maximum adjustment ?
link to beisan instruction:
http://www.beisansystems.com/procedu..._procedure.htm
