Hey guys I am interested in getting a stud conversion kit and im not sure on the length. I have a 20mm spacer in the rear and no spacer in the front. I want the length to match on both the front and rear, is there anyway i can run shorter in the front and longer in the rear to match, or is that a bad thing. Just lmk what some of you guys have and recommend some sizing thanks, Jake
Stud kit Sizing for a spacer
There's generally a 75mm and 90mm option, though I've also seen 63mm, but I think that was in reference to the threaded part for the wheels, total should still be 75mm.
I believe 75mm is good till about 15mm, then you need 90mm for 18/20mm spacers.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
