Rod Bearing Break-in (hint: there isn't a need)
  • Jimbo's M
    I had to do it three times, but as I stated on the old forum, whether I thought it was needed or not is irrelevant. If you don't follow their guidelines, blow your motor and they pull the DME (which is guaranteed), guess who's footing the bill?
  • ATS///Antone
    Technical Service Bulletins are written by engineers for technicians. I've worked with and have been mentored by plenty of people who personally helped engineers write TSBs for many manufacturers. Those aren't for the public to see generally. This one happened to be posted but as customer, it's not for you. It's to help technicians do their jobs.
    That video has good information but that one part is just simply wrong. It's not an opinion, it's a fact. Ocean is right. If they never touched, then they'd never wear, hence never needing to be replaced. The opposite is true and that's why they are considered an item with wear patterns. He also mentioned proper clearances. Our engines are known to have tight clearances for the weight of oil we use.
    Break in your bearings and don't blow off a document written by someone much more qualified to write than literally anyone on this forum. This applies the S54 which our vehicles have. If we blow off good sources of information then what are we? Just another forum based on opinions. That's not M3F.
    This!!!!
  • Arith2
  • Obioban
    The engineers are not stating there is break-in. Corporate training materials are stating there is break-in; there's a difference.
    Everyone is entitled to protecting their assets and doing what they feel best for their vehicle. I am no saint myself and have done plenty of stupid things.
    The purpose of the post to understand the fundamentals and filter out opinions, some which get colorful.
    TSBs are written by engineers. The rod bearing TSB says a break in period is required after replacing rod bearings.
  • jbfrancis3
  • Arith2
    BMW STATES THERE IS A BREAK IN
    My source is BMW so check my attachment.
    1200 miles under 5500rpm and under 105mph.
    This item has a wear pattern just like cams. That's why if you take bearings out, they must go in exactly how they came out. It doesn't matter what "makes sense" if it contradicts fact. We are about right information and BMW knows better on this one considering the engineers who designed the car said there's a break in. This applies to most vehicles though.
  • terra
    Umm, technically crank is not touching (well, no supposed to) the bearings at anytime, it rides on a thin coat of oil. So no break-in needed. I'd still change oil sooner after the bearing job.
    Ideally it shouldn't touch, but if they truly never touched, they wouldn't wear down.
  • Dash1
    What's more important than break-in is proper install. Which is what I think individuals nerf when they have rod bearing failure after a replacement.
  • TexaZ3
  • Tbonem3
    Or at least do an oil change sooner than normal like 1200-1500.
  • Obioban
    .... maybe.
    I'd still do it.
  • jbfrancis3
    started a topic Rod Bearing Break-in (hint: there isn't a need)
    There was a lively thread on former M3F about breaking in rod bearings. There are also DIY's, here and elsewhere, with smatterings throughout warning people about the need to break in their bearings. Typically, its covering the rod bearings that someone has just replaced.
    With that, you may enjoy this timely video from Andre Simon at HP Academy. Among other myths dispelled, he addresses the false statements about needing to break in your bearings. Fundamentally, it simply makes sense.
    The video will jump to 3:22 covering the topic: https://youtu.be/5Ruk6GLJgbA?t=202
