Originally posted by Jimbo's M
Rod Bearing Break-in (hint: there isn't a need)
Originally posted by Jimbo's M View PostIf you guys are so smart about bearings, why don't you give BMW M engineers a ring and tell them they're full of shit. I'll watch.
Originally posted by tnord View PostBMW gave the specs to the mfg, including the acceptable tolerances. then either accepted the out of spec parts that were delivered or didn’t care enough to do a final check prior to or during assembly.
Originally posted by Jimbo's M View PostEasy to just to forget what the dealer said except for one tiny detail in my case, I was still under full warranty even after the second bearing change. Doesn't matter what I think, doing it their way three times was brutal. So, the way I see it is either you do their way or face something effin' up that I would be liable for because the DME or whatever fibbed on me.
I don’t think anyone is denying what the policy was from BMW then. I think the thread is about current policy or need for break-in. And according to post #56, BMW dealerships no longer demand the old break-in period after replacing S54 rod bearings. Which follows other major respected shops like Lang Racing who don’t have a break-in rod bearing requirement. Nor a soon after oil change.6MT SLICKTOP - OE CSL Wheels - OE CSL Brakes - CSL Rack - CSL Trunk - CSL Diffuser - AA Tune - AA Pulleys- AS 40% SSK - 4.10 Motorsport Diff - Bilstein PSS9s - H&R Swaybars - CSL Lip - Gruppe M CF Intake - Supersprint - M Track Mode
Originally posted by oldFanatic View PostWell to be fair all the tens of thousands of us during that campaign were under warranty too.
Originally posted by oldFanatic View PostAnd according to post #56, BMW dealerships no longer demand the old break-in period after replacing S54 rod bearings.2008 M3 Sedan 6MT
2012 Mazda5 6MT
A few Volvo parts
Engineer here. These are hydro-dynamic bearings, meaning they rely on a high film strength in oil in order to lubricate the surface. No metal-to-metal contact should occur.. with that said, I recently changed my bearings with VAC moly-disulfide coated bearings and followed a break-in procedure of 1200 miles of no full throttle, no rev's past 4.5k. After that, I changed the oil again, and now have peace of mind. Is this necessary? probably not, but well worth it in my mind.
Originally posted by JayVee View PostEngineer here. These are hydro-dynamic bearings, meaning they rely on a high film strength in oil in order to lubricate the surface. No metal-to-metal contact should occur.. with that said, I recently changed my bearings with VAC moly-disulfide coated bearings and followed a break-in procedure of 1200 miles of no full throttle, no rev's past 4.5k. After that, I changed the oil again, and now have peace of mind. Is this necessary? probably not, but well worth it in my mind.'05 M3 Convertible 6MT, CB/Cinnamon, CSL Airbox&Flap, PCSTuning, Beisan, Schrick 288/280, SS V1's & 2.5" System, RE Stg 1&SMF, KW V2, CB PS, Apex EC-7R
Did you opt to check clearances with plasti-gauge?
I did not. I choose to skip this step. I know some say it's very critical, however, I spoke in-depth to Calico (the coaters of the bearings), and the fact these bearings are made by Mahle/Clevite (the OE supplier) I was comfortable installing them without plasti-gauge.
If you want peace of mind, check the clearances. If you want peace of mind on top of peace mind, also follow the former "break-in" procedure.
Any disagreement?'05 M3 Convertible 6MT, CB/Cinnamon, CSL Airbox&Flap, PCSTuning, Beisan, Schrick 288/280, SS V1's & 2.5" System, RE Stg 1&SMF, KW V2, CB PS, Apex EC-7R
Another engineer who has written several hundred TSBs for another OEM. Engineers write these bulletins along with a technical service writer who helps translate them for service technicians. They are then published into the network for technicians to access freely. Nobody else has any input into these documents from the technical aspect.
Recalls are another story, because they are managed by a separate team that specializes in those matters. Since this was not a recall per se, there is no reason to view the original service bulletin with skepticism. I can personally vouch for the fact that we are doing our best to fix the customer's car using safe and effective techniques and practices. Random engineers who don't give a F about engines don't end up in those roles. They care and they were trying to fix a quality issue.
- Likes 3
