Originally posted by Ahmed.Alghoul
E46 M3 S54 Vanos pressure tests
Mine doesn't change much between idling and under load (hope that doesn't mean there's an issue with my gauge or something lol), but I wouldn't worry about it as long as the pressure is in spec when necessary (under load).
Also, have you remeasured the pressure after adjusting intially? The fact that your pressure regulator has to be maxed out to get to 115 is a bit weird to me. Mine felt like it had a good amount of adjustment range left still. It might be totally fine, but I would still double check.
Originally posted by gorilla69 View Post
Exactly the same pal.
I sourced another vanos unit, used the beisan stuff from my old one and after I installed it everything works fine; also pressure is 100-105 bars & vanos test is ok
According to BMW, Vanos pressure should be 100-105 bars.
I have found the same problem, I was thinking about changing the restrictor valve but it seems that based on your experience that is not the issue, and I thought so as the valve only comes into play if pressure surpasses the 115bar setpoint. before that it does nothing, My pressure was about 45-50 when warm, but was 100 when cold. I was very confident of the rebuilt I did as I was very careful to install the seals delicately, but it seems maybe I did not.
By the way, drives fine, no codes, rattles, or performance issues (she pulls hard in any rpm), she has hesitated three or so times on me between 2-3k rpm, and this could be the case, unfortunately. I don't drive her much so maybe the issue is there but I drive very little.
Pressure when cold
Pressure when hot
According to BMW, Vanos pressure should be 100-105 bars.Last edited by gorilla69; 08-16-2020, 06:35 AM.
This is interesting. On my car, at the furthest limit of adjustment on the restrictor, my car is 90-100bar at idle. Under load it goes up to 115, but at idle, no dice. VANOS has had the full Beisan treatment. I wonder if the fact that I can't adjust mine to be a constant 115 bar like yours indicates a problem somewhere?
Also, have you remeasured the pressure after adjusting intially? The fact that your pressure regulator has to be maxed out to get to 115 is a bit weird to me. Mine felt like it had a good amount of adjustment range left still. It might be totally fine, but I would still double check.Last edited by heinzboehmer; 08-15-2020, 07:26 PM.
Since you've got a gauge, you can try moving the pressure regulator back into spec. There's a slot for an allen bit at the end of the regulator that is used to set the pressure it operates at. I think clockwise raises pressure and counterclockwise lowers it. I recently adjusted mine and now my pressure is 115 when hot or cold at basically any rpm (it was at ~100 before and would change based on oil temp and rpm).
EDIT: when cold, I was able to adjust the pressure at will, I set it up to 115, but as it warms up, pressure drops...Last edited by maupineda; 08-15-2020, 01:09 PM.
Pressure when cold
Pressure when hot
Originally posted by gorilla69 View PostHi,
I tested my vanos oil pressure and the gauge shows 35-40 bars. Tried to adjust the pressure regulator but response was minimal. Replaced both the regulator (11367838080) and regulating valve (11367830341) but the pressure is still the same. My vanos has been overhauled by BMW specialist using all of Beisan's spare parts.
Any ideas?
Pressure when cold
Pressure when hot
Any ideas?
Was the vanos unit pressure tested on the bench before it was installed? If not there is no way to know whether the beisan seal job was succesful or not.
Are you chasing a specific problem or just doing the pressure test for fun?
Any ideas?
Hi,
Any ideas?
Hi, in your table the pressure is at 107, are you planning to adjust to see if you can set it to 115? or you are just trying to assess seal life.
