E46 M3 S54 Vanos pressure tests
  • gorilla69
    I have found the same problem, I was thinking about changing the restrictor valve but it seems that based on your experience that is not the issue, and I thought so as the valve only comes into play if pressure surpasses the 115bar setpoint. before that it does nothing, My pressure was about 45-50 when warm, but was 100 when cold. I was very confident of the rebuilt I did as I was very careful to install the seals delicately, but it seems maybe I did not.
    By the way, drives fine, no codes, rattles, or performance issues (she pulls hard in any rpm), she has hesitated three or so times on me between 2-3k rpm, and this could be the case, unfortunately . I don't drive her much so maybe the issue is there but I drive very little.
    Pressure when cold
    Click image for larger version  Name:	ColdPressure.jpg Views:	0 Size:	64.5 KB ID:	50449
    Pressure when hot
    Click image for larger version  Name:	HotPressure.jpg Views:	0 Size:	109.0 KB ID:	50450
    Exactly the same pal.
    I sourced another vanos unit, used the beisan stuff from my old one and after I installed it everything works fine; also pressure is 100-105 bars & vanos test is ok
    According to BMW, Vanos pressure should be 100-105 bars.
  • heinzboehmer
    This is interesting. On my car, at the furthest limit of adjustment on the restrictor, my car is 90-100bar at idle. Under load it goes up to 115, but at idle, no dice. VANOS has had the full Beisan treatment. I wonder if the fact that I can't adjust mine to be a constant 115 bar like yours indicates a problem somewhere?
    Mine doesn't change much between idling and under load (hope that doesn't mean there's an issue with my gauge or something lol), but I wouldn't worry about it as long as the pressure is in spec when necessary (under load).
    Also, have you remeasured the pressure after adjusting intially? The fact that your pressure regulator has to be maxed out to get to 115 is a bit weird to me. Mine felt like it had a good amount of adjustment range left still. It might be totally fine, but I would still double check.
  • ATB88
    Since you've got a gauge, you can try moving the pressure regulator back into spec. There's a slot for an allen bit at the end of the regulator that is used to set the pressure it operates at. I think clockwise raises pressure and counterclockwise lowers it. I recently adjusted mine and now my pressure is 115 when hot or cold at basically any rpm (it was at ~100 before and would change based on oil temp and rpm).
  • maupineda
    I tried it, no change. I think I have a pump issue. I reached out to Beisan and he thinks the oil pump disc shaft may be worn, or the disc in my kit is loose vs the disk shaft thus failing to build pressure. The disc in my kit was a billet one from Beisan, not a modified OE.
    EDIT: when cold, I was able to adjust the pressure at will, I set it up to 115, but as it warms up, pressure drops...
  • heinzboehmer
    Pressure when cold
    Pressure when hot
  • maupineda
    Originally posted by gorilla69 View Post
    Hi,
    I tested my vanos oil pressure and the gauge shows 35-40 bars. Tried to adjust the pressure regulator but response was minimal. Replaced both the regulator (11367838080) and regulating valve (11367830341) but the pressure is still the same. My vanos has been overhauled by BMW specialist using all of Beisan's spare parts.
    Any ideas?
    Pressure when cold
    Pressure when hot
  • sapote
    Hi,
    Any ideas?
    This sounds like you have a bad leaky vanos piston seal; could be damaged seal during installation. Or not having enough oil supply from the head: caused by a blockage regulator (the one between the head and vanos).
  • gorilla69
    Was the vanos unit pressure tested on the bench before it was installed? If not there is no way to know whether the beisan seal job was succesful or not.
    Are you chasing a specific problem or just doing the pressure test for fun?
    No it wasn't bench tested (how can you test it like this?), I did the pressure test because after the overhaul it won't pass the vanos test. I 've covered 2.500kms since then.
  • eacmen
    Hi,
    Any ideas?
  • gorilla69
    Hi,
    Any ideas?
  • maupineda
    Hi, in your table the pressure is at 107, are you planning to adjust to see if you can set it to 115? or you are just trying to assess seal life.
  • heinzboehmer
    Originally posted by Ahmed.Alghoul View Post
    Are you sure that S54 Vanos banjo bolt fit size is M10x1.0
    I read in another forum that it requires M12x1.5
    please confirm it and if anybode else have the exact answer please let us know
    I'm not sure what the banjo bolt specs are, but those are the exact listings I bought from (pulled them from my purchase history) and they fit the engine just fine.
  • Ahmed.Alghoul
    This is what I bought.
    Fitting: https://www.ebay.com/itm/M10-x-1-0-S...t/361110675174
    Gauge: https://www.ebay.com/itm/201L-158O-1...i/172993590870
    Works completely fine, but does require you to remove the beauty cover, otherwise the gauge hits it when being screwed in. Maybe get an extension fitting so this isn't an issue.
    ​​​​​​​please confirm it and if anybode else have the exact answer please let us know
  • Ahmed.Alghoul
    Perfect
    thank you
  • heinzboehmer
    Need more information about the vanos fitting adapter size ,where could find online.
