E46 M3 S54 Vanos pressure tests
  • Cubieman
    Originally posted by Arinb12 View Post
    I'd like to also try this, could you please let me know where I can connect the oil pressure guage? Is it under the oil filter housing? Is there a special thread sensor I need?
    Santino what did you use?
    Is this the location?
    You remove your vanos line and the gauge goes there. Here is a few links to what you will need. Raj (Besain) recommend to use red loctite to seal the gauge/fitting. Buy some vanos line crush washers as well because you will use 4 every time you test/re-install vanos line.
    PS: Looks like the gauge my no longer be sold by the same eBay person, look at the specs. Contact Raj at Beisan if you have trouble getting the right gauge.
  • Arinb12
    In the meantime, just to be sure a bad ACC is to blame, you can hook up an external oil pressure gauge to the engine oil sensor and check engine oil if it drops when rev up as shown in previous video, for whatever the reasons. It should not drop.
  • Arinb12
    It is unlikely, the in-feed valve if I recall correctly is preset to 1 bar (which is close to the minimum engine oil pressure at idle) so the VANOS pump uses this oil supply to build up high pressure (115 bar).
    I had to do extensive troubleshooting in my car as some specialists sweared the problem was my VANOS, yet it wasn’t, but keep in mind my car is a low miler (43k) at the time of the issue. One OE disc after, my issue was fixed.
    in Arinb12 case it seems to be wear and tear, but pls share mileage on the unit if known)
    the reality is that an engine with regular oil changes should not see wear in this interface at all as it spins around an oil film. But we know most cars are neglected.
    How can I test the engine oil pressure/confirm.
    Where is the oil sensor? I heard there is a blank hole there that I can attach a manometer to?
    Unit is on 155,000 miles
  • maupineda
    What about the oil regulator valve on the vanos body that is in the centre? Could that also be causing low pressure?
  • maupineda
    I failed the vanos test prior to this due to timing issues at the first part. I decided to rebuild new seals before refitting the vanos after timing. My disc is the original but has been drilled by the previous owner?
    Could it have worn out that much that it no longer produces enough pressure??
    What part is the pump shaft? And what part of this disc could be worn?
    What are my options now?
    Unfortunately, it seems your only option is another unit, if you say your disc is original to the car, and you have low pressure, then wear and tear has reached you, what is the mileage on the car? or your re-drilled OE disc is from a high miler.
    Your test results confirm you have no timing issues, you passed the leak down test, though the exhaust cam moved a bit more than I would have liked, still, within the 5deg tolerance, DIS is complaining about the timing to adjust (retard). another possibility can be to try another solenoid valve body but based on your pressure at idle, and the fact that DIS tests at 1500rpm, is just trying to find lipstick for the pig.
    the sad truth to all this is that changing the disc from one VANOS to another is like moving a rod bearing from one rod to the next, not a good idea.
    If you hop into eBay, you can find a spare VANOS and pray is good, or have a disc manufactured to your shaft dimensions, but I think that is more cumbersome than not, I had to spare a whole VANOS unit to get an OE disc off of it.
  • Arinb12
    Originally posted by thegenius46m View Post
    Interesting you are having issues with the original disk. I'm in the process of swapping vanos units because my original is not producing enough pressure at all with a besian redrilled disk oe disk from years ago. I have been told the tolerances of all these components can get looser as the mileage rises so it's possible. I picked up a 60k mile unit and had dr vanos drill the holes on the same disk I sent out. My car also has a brand new genuine bmw oil pump, chains, and guides so if that doesn't get me back to spec something is wrong lol.
    You also could have a bad regulating valve on the solenoid body. If that doesn't fix it, get an entire vanos unit with the same oil pump disk and just change everything.
  • Arinb12
    Low mileage ones are like gold dust in the UK unfortunately!
  • thegenius46m
  • Arinb12
  • maupineda
    Your problem is not the accumulator nor the regulating valve, but your VANOS pump, which once the oil is warm, does not generate pressure. this is due to either a worn-out pump shaft, a worn-out disc, or incorrect tolerances of the radial pistons.
    I had the same problem, in my case, the issue was the pump disc, I had to source another OE disc, have it redrilled, and the problem was solved.
    to anyone doing VANOS work, I now advise to always measure pressure BEFORE as well as run a DIS/ISTA test, and if all is ok, leave it alone. if you feel you need to fix the play with the exhaust tab, then just make sure you redrill the original to your car disc.
    I am more than sure this issue with the disc is present in many cars, just people do not test for it, also, low pressure does not necessarily mean the VANOS test will fail as when the rpms rise the pressure rise to a point where there is enough of it to actuate the VANOS splines. however, it is pretty upsetting to know you have a non-confirming system LOL
    in your case, your VANOS does fail as the pressure is too low and causes the response times to be too slow.
    EDIT: on the Z4M VANOS test is done at 2k rpms, on the E46 M3 is done at 1500 rpms, so it is more sensitive to low pressure as at 1500 there will be less pressure if your pump fails to be at 115 bars at idle.
  • Arinb12
    Edited to remove
  • Arinb12
    I'm having similar issues with this
    I have tried to run a vanos test and it has told me to check the pressure regulating valve and or the solenoid (solenoid has been checked and has no issues, nor does the block which has been cleaned and is all free moving)
    I ran the pressure tests above and my results are very strange
    On cold engine, I have the following video. The car was left a couple of days and then the valve and tester fitted.
    revving the engine reduced the pressure as seen in video
    It had a nice 115bar pressure and the leak down was not too bad, but not great
    ​​​​​​After the above video the car was still cold, I restarted it after leakdown finished and the following video was the next read out. (Assume oil was more viscous after a couple mins of the previous video)
    Pressure super low! I tried to adjust the regulator valve and it did nothing, I ran out of adjustments.
    I let it warm up and tried to adjust again, only thing I could do was back it out and reduce pressure not increase it to 115 bar; it was the same as the below video for both the cold restart and warm engine (more viscosity to oil)
    Revving the engine increased pressure significantly only for the load time
    This happened on all subsequent tests too
    The attached photos is my vanos test results
    any advise is appreciated. I have just rebuilt the vanos with new seals. I have new sprocket bolts, new chain guide, solenoid block is clean and free moving, solenoid pack has been continuity tested to confirm no cold solder joints, the disc is the redrilled standard that it came with.
    Thanks for the help, I'm assuming ACC or regulator but not sure, also heard about an oil filter between vanos and body that may get blocked?
  • Santino
    Originally posted by BBRTuning View Post
    The blips in the video with the larger pressure drop sounded much longer duration and more aggressive, but it could just be the video. Either way, I don't think these types of comparisons are very useful. It would be better to do a very repeatable test (such as the actual Vanos system test) at the same oil temperature each time and watch pressure drop then, to really be able to learn anything from it.
    I certainly think it's a good idea to check and adjust the regulated Vanos pressure if one suspects an issue. The key-off bleed-down test also does seem to be a decent indicator of Vanos Accumulator condition. Trying to compare different videos of blipping the engine with your foot is less useful.
    I agree, as an autor of these videos its hard to compare pressure drops for this gas blips, as when i input gas agressive the drops are much more significant then, when aplied in a steady fasion (more compared to road use)
  • BBRTuning
  • sapote
    Unfortunately these two videos mentioned here are completely useless to compare. The video in post #1 shows pressure at idle, and then the engine is *very* lightly revved to 2000 RPM or so. In this situation the intake cam is likely not moved at all, and the exhaust cam only partially (look at factory DME Vanos target tables in these low-load sites). The 2nd video shows aggressive throttle stabs straight off idle. In this case, both cams are moved significantly, requiring much more oil volume, so of course the Vanos system pressure will drop much more.
    Compare videos on post #32 (dropped about 30bar) and post #64 (dropped about 5 bar) and they both from the same car with same rpm reving rate. The poster said the pressure still dripped down after replace ACC: "Finally i have replaced a new ACC bottle for the vanos, it still dips pressure whem hiting the gas, but never drops below 100bar (i have operating pressure at 115bar now)"
    115 -100 = 15 bar dropped max
    and this is why I said it's mystery. Post #64 video look normal.
