Yeppers
realoem-bodywork-door weatherstrip front:
outer weatherstrip
L. 51327890453
R..................454
Window down:
peel up up slowly from the detached portion at the rear.
Introduce the new piece at a shallow angle about 1/3 the distance from the mirror and change angle to near parrallel. Slide it in for as much of its length then snap in the rear portion.
then use the heel of your hand to press down along the length of the strip until it's evenly attached.
Scratch the part nos above.
Further digging turned up 2 versions of this trim piece.
one is gloss black
other is shadowline
I believe the M3 is shadowline, but we need verification.
Take a look at the ECS site. Part # 51328227626
Yep. Window down, slide the forward third down in the groove towards the mirror.
Then tamp it down with the heel of your hand, starting at the mirror end and moving to the door handle.
compare with other side until you're satisfied.
