Originally posted by eacmen
I work on my car a fair bit, so I would want a mounting solution that is easy to remove. Advice on this point?
Im in south fl currently, so Ive been paying particular attention to the others who are running these setups in hotter climates. I also want to be able to do track days and autox, but I dont think they put as much strain on the cooling system as idling in 100F while blasting the a/c.
Ive read that running just a 1400cfm puller fan, is not enough in the hotter climates. However, no one has told me that they run just the aux fan consistently in hotter climates with success.
Im open to giving just the aux fan a try for science and if it does cool the car well enough to keep it within normal temps, I might just do the mechanical delete for now until the aux fan dies and then replace it with the spal puller.
dl.M3 and rbg, thanks for the info!! leaning me towards trying just the aux fan
