Door Clips: Two Kinds, Where do they go?
    For the front door, where do the 3 clips that are different go?
    Anyone have a picture they could post showing the locations?
    Check realoem but I believe the 3 grey ones are mounted vertically at the front and the rest are white.
      The ones labeled "1" are gray, the rest are white
        What is the difference between the clips?
          I think some of them have a foam spacer, can't remember for sure though
            I think last time I installed all with that foam ring.
              they all had them on mine. they look identical except the color, probably need a caliper to measure the difference.
                3 gray clips to the front is the fix I needed. Front basically won't clip if you use the white clips
