Originally posted by OldRanger
Ideally, TIG welding would minimize the heat affected zone (HAZ) which results in increased brittleness. TIG needs the metal to be clean, clean, clean so it would require a significant amount of prep on the front and back side. MIG would be easier with larger HAZ and splatter - so you need to cover the area. MIG needs a lot less prep.
Either way, if the crack is all the way through you have to shield the backside with flux since it the weld will be exposed to oxygen. I'd think welding both sides would have a smaller HAZ but I'm not sure.
In this case, it might be worth post weld heat treating which reduces the brittleness of the HAZ.
