Originally posted by S3diment
Can and analog version is finished. Analog Sensor values, gear display, moving graph for AFR or other, startup logo etc. Have sourced some sensors, that working good and not to expensive for gearbox temp & diff temp and Oilpressure&temp in one plug for the blind plug in the Oil filter housing.
Kline version is running on bench fine, but I can not test it in (moving) car until 1. April, because of seasonal license plates.
Also new updated PCB is currently in production. These should arrive in a week or so. Theoretically the cluster display is finished at this moment. But as I said, not „field-proven“ at this time.
As I think this „project“ has a whole lot more potential for further possibilities, but I’m very limited to the small screen size in the cluster (and I want to keep it simple with the cluster display in terms of simple using).
I’m doing at the same time a kind of „Bordcomputer“ for E30 with s54 swap for a friend that replaces the factory BC. With 2.8“ touch, added functions for fault memory read/delete, adaption resetting, G sensor, time stopping, sensors displaying, etc.
