You guys running catch cans? I havent seen anything on this forum about running them. I just bought one, N/A people running them are you catching a lot?
Oil Catch Can
Old forum had quite a few posts on this. People were getting an ounce or so a month. Keeps the intakes cleaner. I'm surprised people don't run more because I wouldn't want oil dumped in my carbon fiber intake.This is my Unbuild Journal and why we need an oil thread
I have been reading up on them lately.... some people say
It is only worth it once you are stepping away from NA engines.(going SC or Turbo)
Others say its a must.
I cant find solid data that it hurts our engines.
I will be running one as well.
I have 2 buddies with s54's heavily tracked, they really recommend it
I deleted mine for weight savings. I would collect quite a bit. It's mostly vapor that gets burned off tho. Inside of cf airbox is still clean even without it.
unnecessary imoDD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Not running one, not going to be running one. Assuming you drive more than a couple miles per drive, most of what it collects (water) burns off. The rest (oil) I'd rather keep in circulation.
Our oil separator system is reliable and works really well. I have no desire to add complexity, weight, and additional upkeep for no tangible benefit in exchange.
Well that's good to hear.Originally posted by Tbonem3 View PostInside of cf airbox is still clean even without it.This is my Unbuild Journal and why we need an oil thread
Previous owner of my car installed a Radium catch can with the CSL intake and it leaks all the time. It's 90% track, 10% street and I barely get any liquids (but there is a lot of leaking, so maybe it's just seeping down the bottom of the drug bin). So YMMV, but I'm not convinced.2018 Grigio Telesto F80 M3 DCT | :: Bone Stock ::
Water evaporatesOriginally posted by e46mpwrd View PostI have the Radium catch can with the Stock intake. No leaks, it collects liquid in it after some miles. For example after driving to/from Mpact there was less than an ounce. Id rather keep that out of the intake.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Sure, but its not all water if that what you are getting at. Definitely an oily water mixture (looks like bad coffee) that would be sprayed all inside my intake. Based on what I have seen it would be such a small amount but Id rather it be clean. I would post pictures but I haven't driven enough.Originally posted by Tbonem3 View Post
Water evaporatesLast edited by e46mpwrd; 09-21-2020, 09:45 AM.'06 IB/BLK 6SPD PN66072
This.Originally posted by Obioban View PostNot running one, not going to be running one. Assuming you drive more than a couple miles per drive, most of what it collect (water) burns off. The rest (oil) I'd rather keep in circulation.
Im not sure if its the rebreathed oil vapors or an oiled bmc filter i used forever or both or neither but after 150k miles i had the pleasure of hand cleaning my itbs off the car. The other side of the flaps is caked up black sh!t everywhere.
I was hoping this would be prevented somewhat by the catch can. Is this not the case?
