So I was pulling off the QD mount from the steering column to do some re-wiring. In the process I think I may have damaged the clock spring and the previous wiring job.
Q1. Does anyone know the part number for the wiring pins for the 6 pin clock spring connector? And the tool needed to remove the pins?
Q2. What is this metal clip on the clock spring for? Is the plastic part supposed to have 4 tabs on it?!? It was on the floor when i pulled the wheel hub off.
