Mechanic shops in Michigan
    I need to have the rear subframe reinforced and rod bearing replaced, which Michigan shops would you all recommend?
    thanks
    Where in Michigan?
    maw
      Where in Michigan?
      maw
      Macomb / Detroit area but I’m willing to drive 100 miles or maybe more if there is a well reputable shop
        they replaced my entire RACP. Happy with the service. They have an e46 race car built in house.
        2007 Imola Red Z4M Coupe
          Or Steve’s European (https://www.steveseuropeanauto.com) or Satish’s Motorwerks (https://www.motorwerksgroup.com/). They’re all car guys, and these are no stranger to them. They service AMG and Audi for me. M3 is located elsewhere. This is probably more for Satish.
          GL,
          maw
            I used Nikolas Motorsport in Sylvan Lake back when I lived in Ann Arbor and owned a 335i. Not sure if they are farmiliar with E46 M3s but maybe worth reaching out.
              Thanks everyone!
                It's not the first time I hear about APG racing. 2 E46 M3 owners I met at a track day at Waterford Hills told me they had their subframe reinforced there too. I am considering having it done, but I'm also thinking about DIYing the BMW structural foam procedure. It seems like an elegant and efficient solution that's easily doable in a day... I am struggling to find the product.
                  APG took out my entire RACP and welded on a brand new one which was reinforced with redish plates. not many shops can do this kinda service. THhs was 4 years ago and I have no complaint. if they can do THAT, then a repairing a few cracks would be a joke for them. they're highly specialized in suspension and chassis work.
                    I was quoted $5900(+ more if subframe has cracks) for the following work (all parts provided by me). It seems a bit steep, I was expecting something around 3K.
                    1. Engine Rod bearings
                    2. Rear subframe reinforcement bottom plates (CMP plates)
                    3. Rear subframe reinforcement top Beam reinforcement (CMP)
                    4. Rear bushings + rear camber arms
                    5. Front control arms + bushings + tie rods
                    6. Coilovers + front camber plates
                    7. Motor mounts + transmission mounts + flex disc
                    what do you all think?
                      What is the labor rate per hour?
                        Where TF was that?!?!
                        maw
                          maw
                          APG racing / Autocore
                          Labor rate is $110
                          Nikolas motorsport said they cant do the subframe reinforcement, I'm going to call a few other places as well. My buddy in California got the same things done to his car for $3400 at EAS. I was kind of expecting something similar, I didn't know automotive labor is this expensive in Michigan.
                            Labor rate is $110
                            That is approximately 54 hours of labor or just short of 7 full 8 hour working days. That certainly seems excessive. It would be interesting to see the break down of where they allotted those hours.
                              Call Satish at Motorwerks (248) 668-6793... tell him I sent you... I’ve given him a heads up... GL
                              Cheers,
                              maw
