Originally posted by Tbonem3
e46 M3 Tire Sizing Thread
So your saying with the 9.5+22 I will have inner coilover rubbing? Therefore needing a spacer up front? What about rears?
9.5 to 10" is a half inch or 12.7mm. So on both sides of the wheel, the 10" with stick 6mm farther out. With 25 offset, the whole wheel will come in 3mm more than the et22 wheel. The final result will be that the 10" wheel sticks out 3mm more than the 9.5" wheel, but the inside will also be 9mm farther in.
A 10" wheel is harder to fit more due to the inside than outside. If you can fit the 9.5et22 up front, because you have camber plates, you can fit the 10" . The bigger issue will be innner rubbing on suspension.Last edited by Tbonem3; 04-25-2022, 07:49 AM.
Thanks for quick reply! By “no issues” I meant like the need for spacers and or rolling/cutting fenders etc. My car is not daily driven and experiences the occasional track day or canyon most of the time. I always have a hard time understanding these wheel specs lol but is x9.5 +22 any more or less aggressive than a x10 +25?Originally posted by Thoglan View Post
Depends what you mean by no problem. 18x9.5 et22 with 265/35 is a very common size. It is very aggressive on the front though. Requires at least 3 degrees of negative camber, which is pretty compromised for a street car.
Depends what you mean by no problem. 18x9.5 et22 with 265/35 is a very common size. It is very aggressive on the front though. Requires at least 3 degrees of negative camber, which is pretty compromised for a street car.Originally posted by narudnad View PostCan someone advise if 18x9.5 +22 fit on our cars without any issues? And if so, what tire size you may recommend? TIA!!
Yes, 275 18x10 et 25 is the standard rear flush with no spacers or rubbing setup.Originally posted by Fresh1179 View PostI don't mean to inject additional variables but can someone confirm that an 18x10 et 25 with 275's will fit without rubbing given the proper camber setup. I would like to eliminate spacers on my track car.
In this thread looking for something else, but my experience is you need to keep variance really close if the rears are smaller than fronts; rears being BIGGER diameter/circumference than fronts isn't an issue within reason. I believe I've run 1/2" larger in rear with zero dsc issues. My belief is the dsc thinks rears are spinning under accel if the rears are turning much faster than the fronts, so with larger rears, this comparison is never going to trip unless real spinning occurs. There could also be some sort of "out of range" comparison too that would be an issue if rears were abnormally larger, not sure.
ADS
No that's E9x tire spec. Go with 245 & 275 or 235 & 265.
Also, .5" diameter is large. Look at rolling circumferences in the first post.
Looking at:
245/35/19 (25.8" dia) Front
265/30/19 (25.3" dia) Rear
0.5" diameter delta (2%)
Will this be OK for street use with respect to DSC?
Tirerack has 275 in stock and 285 in stock in less than two weeks.Originally posted by Cb3319 View PostGood morning all…so it seems Michelin Pilot 4S is not offered in 275/30/19 or 285/30/19. The local vendors seem to only be able to get 275/35 or 285/35. If I read correctly, the difference is that the 35 will stand a bit taller, right? Again, my fronts are new and 245/35. Thoughts?
here ya go. A 245/40 and 275/35 have an almost identical diameter. A 245/35 is almost an inch shorter than a 275/35. If you look at the revolutions though, the difference is hugeOriginally posted by Cb3319 View PostGood morning all…so it seems Michelin Pilot 4S is not offered in 275/30/19 or 285/30/19. The local vendors seem to only be able to get 275/35 or 285/35. If I read correctly, the difference is that the 35 will stand a bit taller, right? Again, my fronts are new and 245/35. Thoughts?2 PhotosLast edited by Rkymtnrider; 07-03-2021, 09:18 PM.
I just fitted 235/40/19 front and 265/35/19 rear PS 4s to both maintain rolling circumference front to rear as well as to try to dial back the natural speedometer error.
