How to disable the low window washer fluid light?
    I removed the tank and now the light is on, of course. Is there an easy way to disable low window washer fluid light? Resistor maybe?
    Just short the wires. you can either make a jumper for the connector or cut the connector off and short them etc. its just looking for an open circuit for the warning light so close the circuit and it goes away.
      Any idea which wires they would be? Or how I would identify them?
      Thanks!!
      Lazy boy looked it up online. thanks!
        Which wires were they? I don’t have access to my car at the moment and would also like to disable the light
          Just the wires that go to the washer level sensor... so follow for a disconnected connector down there that originally went to the sensor before you removed the tank and short those wires... can't remember the exact colours or whatever...
            I think they are hanging to low for me to see them without removing the fender liner which I will be doing this weekend. I'll take picture when I find them
