Originally posted by Ceelooboob
View Post
4.10 Ring and Pinion Gear Whine Noise
Will add for purposes of public data, since we spoke via PM. My wife calls my car Chewbacca, it whines like crazy. Started on poly subframe bushings and poly diff bushings. Went to stock diff bushings (stayed with poly subframe), still whines.
Youtube DIYs and more
4.10 here, there is a noticeable whine, but that is to be expected. I would say it's all relative to how sensitive you are to high pitched noises, older you are the less you will likely notice. As everyone else has stated, bushing choice will play a major part in noise transmitting to cabin.
I'm always curious as to whether those who are very bothered by it have a completely stock interior down to the styrofoam that holds the pump in the trunk.
Skip to 12:50 and he shows a perfect pattern on how the gears are supposed to touch.
BUY MERCH HERE- http://bit.ly/FPMERCH Merchandise Purchases will be going towards sponsoring vehicle ride alongs for Veterans and First Responders! For Veter...This is my Unbuild Journal and why we need an oil thread
Another 4.1 user here.Originally posted by Ceelooboob View PostHi all,
I am trying to gauge other people’s experience with 4.10 gear sets and whether or not they are getting noticeable gear whine. I’ve read up a lot and see many people saying their 4.10 gears don’t whine at all while others say they do whine and it’s normal. I recently assembled a 4.10 differential and the gear whine is worrying me that something was setup improperly.
Just for back ground, I put together my diff with a friend who is a BMW tech and pretty familiar with differential assembly. Originally I put in all new pinion and carrier bearings, new seals, new Wavetrac LSD unit and BMW 4.10 gear set. We sourced pinion and carrier shims to properly set pinion depth, carrier shims for back lash, set pinion preload and carrier preload to spec. Pattern looked ok, centered on coast and drive side etc. I already had all 3 AKG poly diff bushings , subframe bushings, motor mounts , trans mounts etc. I Put the 4.10 diff in the car, it whined from the start, drove a few hundred miles, same thing. The poly diff bushings always caused a faint whine with my stock 3.62 diff but nothing like the 4.10’s do. I took the diff back out, checked everything , looked fine, sent the gears for REM finishing to hopefully quiet things down. Put the diff back together with REM treated gears checking everything again, all is within spec again. Differential still whines , slightly quieter , but barely. I’m going to drop it out again and possibly take it to someone for a 2nd opinion, make sure everything is assembled properly and if so just switch to stock diff bushings to quiet the whine (I hate the whine).
What has everyone else experienced with noises and their 4.10 gears?
Anybody know any reputable differential shop in SoCal that could looking things over for me on my diff?
Thanks all!
In my build thread I documented my gear patterns. I tested two setups, and the one with the original shim is best, but still there is a slight whine. my gears were not REM as I had read it does not really help much.
OP, or anyone in the know, where can I find the depth tool? I have searched up and down with no luck. I am motivated to get the diff down once more if I can find the tool just to double check.
Sorry I’m super late on the reply.Originally posted by maupineda View Post
My buddy had a depth gauge just like this one https://www.yukongear.com/shop/tlsm02 .
Also, my diff was sent to diffsonline since I felt like I could never get it right. They did their magic, much quieter, no issues over the last few years.
