Last month made a post about if there is a way to find out if i had a tune, using a octane booster removed some pinging i was hearing.
It was mentioned to get a leak down test to determine if I had head gasket issue.
I finally had some time to schedule a compression and leak down test at a shop. The results kind of worry me based on some searching if done on this forum and other sites. However the shop said the results look fine and shouldn't worry too much about it.
They mentioned that they couldn't reproduce the pinging noise, and that may be because there is still some octane booster in the fuel. I did fill up with about 10 gallons of 91, so there should less of it by the time the shop had the car.
So here are the results:
Compression Test:
1. 160psi
2. 150psi
3. 155psi
4. 170psi
5. 160psi
6. 160psi
Leak Down:
1. 10%
2. 10%
3. 5%
4. 5%
5. 5%
6. 15%
I did order a compression test kit that ill try on my own once i receive it to confirm findings above
Leak down value on cylinder 6 worries meβ. Other than that the car works great, no codes no misfires.
Compression Test:
1. 160psi
2. 150psi
3. 155psi
4. 170psi
5. 160psi
6. 160psi
Leak Down:
1. 10%
2. 10%
3. 5%
4. 5%
5. 5%
6. 15%
