Help with Steering Wheel controls for Xtrons Headunit
    So my old Xtrons headunit died, but it lasted 8 years, so I thought I would give them another try.
    Here is what I got:
    Android 15 Touchscreen Radio Stereo CarPlay Bluetooth 5.4 4G 128G for BMW E46 M3
    I plugged in the connector that slides, and the radio antenna and it appears to work except for the steering wheel controls.
    Any help in getting the steering wheel controls to work would be great.
    Also how do you make it so that the lowest volume level isn't so loud.
    Do I need to plug any of these in?
    ​Click image for larger version  Name:	PXL_20261025_172056241.jpg Views:	0 Size:	53.5 KB ID:	613400 Click image for larger version  Name:	PXL_20261025_172103346.jpg Views:	0 Size:	50.2 KB ID:	613399 Click image for larger version  Name:	PXL_20261025_172113820.jpg Views:	0 Size:	52.7 KB ID:	613398​
      There should be a small decoder box for the steering wheel controls.
      An aftermarket Android head unit should support steering wheel controls, this function is usually supported by a CAN-BUS decoder box which connect with a small plug from the power cables. The BMW E46 Android head unit can support steering wheel controls. While if you find your steering wheel control does not work after installation of […]
        The head unit can detect the car going into reverse, but still no steering wheel controls. Trying to learn the steering wheels controls doesn't appear to work either.
