Took off my water pump today, and the thermostat was stuck to the housing (managed to get it out after a while), there’s a bit of gunk in the thermostat housing and some corrosion. And the water pump housing on the engine is rusty as are some of the metal pipes slightly, did a bit of scrubbing and seems a lot of it is coming off. I assume someone used tap water or mixed in some wrong coolant into there. Any advice as to what to do? Sand down the engine surface a bit with wet sandpaper or a Brillo pad or something? I can post a picture tomorrow as forgot to take one today. Thanks in advance
Would it also be beneficial to change the thermostat housing or would cleaning it up be enough? As it’s rather hard to push the thermostat into place, but I think it should fully go in
