I have a 2002 M3 that has about 320 hp at the wheels and a 4.10 differential. When I did the Vince bar, I installed Bimmerworld solid subframe bushings. I used a light coat of grease to aid the bushing install.
I have learned that hard acceleration (track conditions) can Actually force the subframe away from the body on the rear mounting points with enough leverage that the subframe slide slides out of place (vertically) on the rear bushings. The OEM washer retains it, preventing a catastrophic situation.
Is this a ‘me problem’?
I’m trying to determine if I can solve for this (a second time) by having some sort of spacer machined or printed to hold
