Help finding a parasitic power draw
    Originally posted by dog2bert View Post
    It has behaved itself over the last 4 days of not driving. Only thing that has changed is replacing the blown fuse.
    that sounds like an improvement!
      why the powerbrobe tester at the batt post/cable fed anything to the OBD port?
      I think F43 is to keep the clock counter alive and all of the gauges calibrated indexes values with key off. Maybe an aged leaking electrolytic cap causing a low resistance short circuit on the cluster pcb blew F43, and the cap trace had opened or the cap itself blew too, no longer a cause of the low resistance to drain the batt.
      sapote The powerprobe I had plugs into the OBD port
        I don't know anything about the Powerprobe, but from the name I thought it's for measurig some sort of current and has nothing to do with OBD.
        Anyway, F43 is for the cluster only and I don't think anything connected on the OBD can blow it.
          Unfortunately, dead battery again after 2 days. I guess I will start the process all over again.
            Do you think maybe the car behaves itself if you have never turned it back on since disconnecting the battery?
              Could it be the trunk lights? How much do they draw?
              I have the car tricked into thinking the trunk is closed and they are not coming on.
                trunk light on for 2 days will drain the batt. If not sure just remove the bulbs.
                  The mutlimeter turns its screen off, but I think it is still letting the power flow, because I can open the car door and the car does it start up routine
