Hi all,
I just 420G swapped my Z3M Coupe and the resulting shifter force is uncomfortably high.
I printed an adapter for a load cell to test, and its about 5-6kgf to put into gear. I also tested on a Z8 and the force was 3-3.5kgf, which feels much more comfortable to use.
I measured the lever ratio of the Z3M stock shifter and an E36 M3 stock shifte. (Edit: I have been informed this is not a stock E36 M3 shifter. I have no idea what shifter it is.)
As you can see, there is a huge difference in the ratio of these two shifters.
The E36 M3 ratio was 7.8, and the Z3 M ratio was 3.3
The Z3M shifter is essentially a shorter short-shifter than just about anything I have seen on the market.
Id think if I could increase the shifter ratio to 5-6 it would be a good compromise.
Can anyone measure the ratio of the E46 M3 OEM shifter, the E60 "short shift" upgrade, or any other OEM type shifter?
The ratio is simply (distance between the center of the ball joint to top of the shifter) divided by (the distance from the center of the ball joint to the selector rod joint hole at the bottom)
The part numbers I am considering:
OEM E46 M3 25117527255
E60 diesel 25117527261
M3 Performance 25117527259
E60 "short shift" 25117546373
OEM E36 25117527247
OEM E36 25117527247
222mm long end
