So I was installing new lemforder tie rods for my m3 a couple of days ago and noticed that my passenger side tie rod was over a cm shorter than the driver side. When I tried to match the new tie rods, the passenger side ran out of threads before I could match the length of the old one. I checked if my steering wheel is mechanically centered with the steering rack and it is, and i zeroed out the toe, but the passenger side is as short as I can make it and the wheels still point right when the steering wheel is straight. So I’m wondering if theres maybe something fundamentally misaligned in my car to make the passenger side tie rod that much shorter with the wheels straight? Also the new outer tie rods are unpainted aluminum and dont have the M stamp anymore but dimensionally look the exact same as the old ones, and the inners look dimensionally the same again except they have less threads available than the old ones. Thanks.
Toe issue
Unless the wrong part was in the right bag i don’t think so. Received the correct part number for the m3 inner and outer tie rods assembly. Doesn’t change the fact that the original I took out was much shorter on the passenger side too.Originally posted by sapote View Post
Then you got the wrong tie-rod (total length from rack end to ball joint).
For the last time the new parts are correct. I just found out that the right tie rod i took off was modified by the previous owner to extend the inner rod’s threads and cut off the excess. So clearly this has been a problem in the past and that was their solution. No clue how to tackle this.Originally posted by sapote View PostIf the rack is at the right position and the tie-rod adjusted to its shortest length but the R wheel still points to the right then the rod is too long, wrong part.
The added threads look terrible and I wonder if the nut can turn easily over them.
Wow, what sort of collision on the R wheel that bend the knuckle inward that much with the tie-rod/rack pushing against it. I mean the wheel covered and protected the knuckle. Wonder if the wheel got hit by the rear side inward, this pulled the knuckle outward and bent it inward by the tie-rod (can the tie-rod pulled and bent the strong knuckle?)
Yea pretty wild. Iirc it was totaled at one point due to suspension damage so Im assuming this is from that. I suppose that’s one way to fix a bent knuckle without replacing it haha.Originally posted by sapote View PostThe added threads look terrible and I wonder if the nut can turn easily over them.
