Hand brake not ratcheting?
    Annoying new thing broke: the button at the end of the e-brake handle popped out, and the handle will no longer ratchet (but the parking brake engages if I pull the lever up and hold it there -- so this is a handle mechanism issue, not the e brake itself thankfully).
    If I remove the boot, I can jigger a little lever inside the lever mechanism to get the hook at the end of the long rod that the button's attached to to re-engage, and the button sits as it should again. But, the handle still won't ratchet, and if I push the button it just pops out again.
    I'm having trouble seeing what degrees of freedom I have to examine here to see if this is fixable or something in the mechanism is fundamentally broken...
    anyone ever deal with this before??
