E46 M3 cylinder 6 Misfire
    i have a 2002 bmw m3 with 185k miles, owned it for the past 10 years. Recently cylinder 6 started misfiring. Vanos, rod bearings, valve adj all done 50k miles ago. I have tried new spark plugs, swapped injectors, swapped coil packs (3 times all work on the other cylinders) , new valve cover, checked itbs. One day i will start it and it will run great, the next start it will misfire. On startup it will typically thunk a couple of times and that is cylinder 6 misfiring, till eventually it will turn the cylinder off and it wont run at all. Not sure on what to do next. Did a compression test and all cylinders are 175+ even 6. Seems to happen more when i hold the throttle steady at around 2500 rpms and if i rev it out quicker the misfire goes away. Any ideas? I tried messing with wiring to coil pack and injector but it doesn't seem to make a difference.. Not sure why one startup it will run good, the next it wont. Any ideas?
    Leakdown, just because you passed compression doesn't mean you can't possibly fail a leakdown. That is what I would do next. Plus you get the added benefit of additional knowledge about your engine's health at 185,000 miles.
      ^ this. Also, scope cylinder 6. If it passes a leakdown, then it could be a valve or valve spring issue. I have only seen one example of a broken S54 valve spring.
      What codes are you getting? ECU swap would be an easy test as well. Assuming wiring is not pinched somewhere or a bad ground on the coil harness.
        im only getting a cylinder 6 misfire. eventaully i get a dme code of cyl 6 misfire without cutout till it turns into a cutout. I wish i had a spare ecu but i dont....
          Originally posted by Dvd1371 View Post
          im only getting a cylinder 6 misfire. eventaully i get a dme code of cyl 6 misfire without cutout till it turns into a cutout. .
          In this moment if you cleared the error codes does it run normal again? If injector and ignition coil circuit are good then it should run normal again for some time.
            Theres times when i start it and it runs perfectly fine for 10 minutes and there times when i start it and it misfires right off the bat. If i shut it off and restart it it stops misfiring sometimes and sometimes it doesnt....
              Unplug pre cat o2 sensors and test drive. See if the misfire disappears while under steady throttle.
              Edit: but in thinking you've got one cylinder so unlikely to help, not a bank of cylinders misfiring.
              If the misfire, no matter how you swap coils, plugs, or injectors stays only on cylinder 6 then I don't know. While I realize the leak down may seem improbable to help I would still do the leak down simply to eliminate mechanical problems once and for all. At least then you would know for sure its electrical, fuel system , or vacuum related somehow.
                So you didn't try to clear the codes. Try it to see what happens in order to narrow down the issue.
                A good cheap tool to have and for clearing the codes:
