Hope you guys can help me out, kind of have a few issues I think are related.
Under hard acceleration, past 5000 RPM, it'll feel like I've hit a flat spot in the throttle for a split second, then the car will continue accelerating. This can happen once or twice while in that same gear. Overall, probably has happened 3-4 times the last 3 months. Have taken it easy on the car because of it, and feel like it only happens when I'm flat out. Not a lot of opportunity to drive like that in my area, so haven't has a chance to replicate it.
Fast forward... The last 3 weeks, I've had two instances where I got lights on my dash.
1st time, I was in 1st from a stand still, accelerated pretty quickly (90% throttle). At about 6500 RPM I hear a "ding" all 3 lights (EML + Traction + Yellow Brake Light), full throttle cut, car goes into limp mode. Restarted after 2 minutes, fine for 2 weeks.
2nd time, driving, don't think its too spirited, maybe in second, hear the "ding," car cuts out for a split second but continues to drive fine; but now I have the Traction + Yellow Brake Light on.
I will pull codes, but want to see if someone has a similar experience because this all feels so specific.
Definitely want to start by change my speed sensors, but having a hard time getting part numbers. If anyone could point me in the right direction, would be much appreciated.
Also, might want to change out my pressure sensor(s?) but can't find a late model car DIY. Also,do I need 2, and are they identical?
