Porsche 996 Brembo BBK Conversion Install
  • maupineda
    I tinker with the pad sensor and came up with this. it looks pretty stealth and factory fit if you ask me
  • WOLFN8TR
    The clearance on my rears were the same as yours, I just added two SS washers between the bracket and calipers.
  • Tbonem3
    That's how it is. It can get a little tighter depending on thickness of paint/powder coat. You could grind it down a bit if you want, wouldn't be very visible.
  • dl.m3
    I was doing some test fitting before final assembly. For some reason, my rear rotor is extremely close to the calipers. This is on both sides, using Rallyroad brackets and OEM ZCP rotors, 328mm. See images. Anyone else have this issue? There's probably less than 1 mm of clearance but I'm just thinking thermal expansion of the rotor on track day may cause issues.
    I've test fitted the pads and they sit correctly and fully contact the rotor. Should I be concerned?
  • WOLFN8TR
    Don’t the calipers mount radially to the adapter bracket? The bracket doesn’t have to come off for servicing dampers does it?
    The dampers have 3M adhesive on them which sticks to the brake pads so you can't just pull them out.
  • r4dr
  • Titaniu//M
    I'd consider red Loctite or equivalent on the bolts holding the adapter to the hub as well. It will be a bitch to get it off if you ever need to, but huge fan of that over a bolt backing out.
    If you run dampers, you will need to pull the caliper off to swap pads. You'd be shooting yourself in the foot putting red loctite on the bolts. Maybe blue (non-permanent) loctite will do if you are paranoid.
  • r4dr
  • duracellttu
    Thanks for the responses. I’m going to sand them down
  • Johnvu
    Originally posted by Titaniu//M View Post
    When I painted my calipers, I masked off the entire contact surface that the washer sits on. I think it's best to leave that part unpainted- then there's no way to tear up the paint/powder coating. Paint can expand/contract as it heats up or cools down and affect the tension of the bolt.
    100% agree here. If you have powder coating on the caliper where the contact points are, you need to sand it off until you get down to a smooth metal surface. The last thing you want is for the bolt to come loose at a track day or from continuous heavy braking.
    It looks pretty fully powder coated but it can result in a crash or your caliper falling off... LOL.
  • Titaniu//M
    For those who are using the Rally Road rear adapters, the the kit came with a set of socket cap hex bolts with locking washers. Did any of you try to source flat washers so the locking washer didnt tear up the powder coat / paint? The calipers has an odd sized shape that would require a 20mm outer diameter and M12 (12mm) inner diameter washer. Not having much luck finding one off the shelf at the local hardware store.
    What are you guys doing?
  • Tbonem3
    You don't want tension?
  • duracellttu
  • maupineda
    Originally posted by HighOnLSB View Post
    So I am following this DIY to install my 996 brakes finally over the last couple days and have run into this issue regarding pin clearance on one of my rear calipers as well.
    I purchase a mismatched set of rears, but with correct part numbers for our application, and seem to have one carrera and one boxster caliper. The carrera caliper has perfect pin clearance on both sides of the rotor, however the boxster caliper does not.
    When I originally mounted the caliper with p0lar brackets it was a tight fit but I thought it was nothing serious. Turns out the outboard pins were binding on the rotor and I never noticed. After a quick test drive I find out that the outer face of the rotor has been damaged. A new rotor and new RallyRoad brackets later and I am trying to tackle this issue properly this time now that I am aware of what’s going on.
    Does anyone know what the minimum clearance needs to be? Even with the supplied washers from RallyRoad the outboard pins are very close to the surface of the new rotor, maybe only 1-2mm clearance. Is this enough clearance to be safe? Or do I need to continue to try to remove material from the pin?
    Click image for larger version  Name:	160CAD00-8664-4E10-91B4-BC9CA266451F.jpeg Views:	0 Size:	60.8 KB ID:	37880
    Click image for larger version  Name:	D5FC3288-2E87-42CE-BBE3-3105509E98F3.jpeg Views:	0 Size:	60.8 KB ID:	37879
    I think you will be fine. the rotor is 20mm thick, and the spacing between the pins is 23 (at least in my set, which is also from a Boxter S), so there is will only be 1.5mm on each side. with heat, the disc will expand radially only so you will be ok.
  • duracellttu
    I took some measurements and I think the pins in the callipers are not really an issue. Please see the image below with some references I added.
    A --> B = 61MM
    A --> C = D --> B = 19mm
    A --> E = F --> B = 19mm
    C --> D = 23mm
    Based on the above, the pins are centred in the rotor ditch of the calliper.
    Click image for larger version Name:	Caliper.jpg Views:	0 Size:	139.1 KB ID:	37836
    I still have tape on the pins as I have my clear coat pending, but I am for sure not 3mm off as I saw when mounted for fit test. at least not in my case. the pins' length is symmetric side to side so if I center my rotor between them, I am centring the rotor in relation to the calliper monoblock.
    I hope this makes sense and is useful to others.
    so are you saying this is a RR adapter tolerance issue?
