I’m trying to nail down the culprit for my bank 1, sensor 2 (post cat) code I’ve been getting.
My O2 sensor is new and the heaters seem to be working (the 2 heater lines are drawing 2.7 amps).
next I went to test connection on harness to DME, in case if line is burned or cut. My red wire is generating 12V when key is in position 1. I checked connections with multimeter for lines on harness connection and X60002 connector.
yellow seem to be good and rightfully giving signal with pin 16.
black is suppose to go to 22, but there is nothing there. I guess that’s expected since it’s ground?
brown is suppose to go to pin 7, but I get no signal. What’s interesting is brown on sensor side is getting connection to pin 5. I thought this should be empty per diagrams I’ve seen. The other interesting thing is red on sensor side is giving me a connection signal with 7.
does this sound right???
FYI - couple of years ago, I had a CSL airbox with flap installed by a shop. My reading of the wiring changes is just the addition of wires to pin 8 and 9 for flap sensor.
I appreciate any help on this. I’m in OC (Irvine California) if a local sees this and can lend a hand.
thanks!
thanks!
