Originally posted by Obioban
View Post
Highest Mileage Cars?
1989 325i sedan - track project coming soon!
2007 GX470
build/journal
ig: @zzyzx85
Interesting. Guess this engine had been lucky then.
Originally posted by tnord View PostIf I can find a car that's been through the rebuild process, had the sleeves replaced, etc, and pay an extra $5-$10k for that particular car, I can get behind that.
Also, a higher mileage engine thats not been thru any major issues/rebuilds actually might point to a well built motor from the factory. A keeper
Originally posted by yhp2009 View Post
Also, a higher mileage engine thats not been thru any major issues/rebuilds actually might point to a well built motor from the factory. A keeper"your BMW has how many miles!?"
2007 GX470
build/journal
ig: @zzyzx85
Originally posted by tnord View Postno, of course not all engines have issues. I think the IMS, if left unaddressed affects something like 6%-10% of cars, as admitted by Porsche in the class action suit, and it's the most common issue. From what I've been able to discern, is that somewhat standard practices of what is generally viewed as caring for the car, like letting it idle for a while to warm up, is actually harming the car. Same thing with OCI, even if you follow the factory recommendation of 15k miles, that's increasing your odds of having a problem. And on and on.
bore scoring, cracked heads, D-chunk, etc individually are probably like a 1-3% occurrence. Which, if I was looking at a $10k repair.....that's one thing....but it's really a $20k rebuild, doubling your investment in the car. I haven't quite mentally got past that yet.
If I can find a car that's been through the rebuild process, had the sleeves replaced, etc, and pay an extra $5-$10k for that particular car, I can get behind that. However, it's not too much more of a jump to get the 997.2 with the 9A motor that doesn't have those issues in the first place.
- Likes 2
except I don't want a turbo. and a GT3 is double the cost.
Ive thought about this as well. I think one thing to also consider is how well its been rebuilt. I mean we give these indy rebuilders too much credit if we automatically assume that their rebuilds are somehow more reliable... or even competently rebuilt error free.
Also, a higher mileage engine thats not been thru any major issues/rebuilds actually might point to a well built motor from the factory. A keeperLast edited by tnord; 11-02-2020, 07:34 AM.
224k for me. Rod bearings were done under recall before I bought it with 27k. Suspension is all aftermarket but powertrain is all original. Things break, I fix. Nothing major though except water pump at 77k and a couple starters (OE died and reman one lasted just a year, but fine since that was replaced).
Originally posted by Obioban View Post200,000+ on the M3 wagon, 195,000 on the M5, 160,000 on the M3 (... though 20,000+ of those are on track).
All of them drive better than when new. All of them have original engine internals (other than rod bearings, on the S54s), transmissions, differentials, etc. None of them have original cooling systems or bushings (as I replace those items at 100,000 mile intervals).
Originally posted by newton22 View Post
Not worried about timing chain guides or rod bearings on the S62?
I do oil analysis on the M5 (and all the cars) with every oil change, but so far the lead has not elevated. The M3s have had rod bearings done with the metals elevate, in a similar fashion, when they have called for it. IMO the S62 doesn't really need rod bearings unless you rev it to the redline... but, unlike the S54, there's not a ton of incentive to bang it off the limiter-- peak power is 500rpm before redline. Without daily repeated redline hits (like my S54s), the original bearings seem to be holding up fine at ~200,000 miles on the M5.
I actually think the e39 M5 is the most reliable "real" (pre turbo) M car. No significant engine issues, no significant trans issues, no significant diff issues, no signifiant chassis issues, no significant electronic issues, way longer than typical BMW cooling system life.
... though undoubtedly part of that is that it has the least "real" M engine of all the pre turbo cars other than the S52 and could only be had with a traditional manual. :P
2008 Black/Black M5 Sedan
For sale: 6MT 2008 M5: https://nam3forum.com/forums/forum/c...fully-modified
- Likes 2
I did the chain guides at 100,000 miles, but it was a huge waste-- they still looked like brand new. So long as you replace the tensioner every 100,000 miles, you can leave the guides alone on the S62. The M62 runs considerably hotter than the S62 (by design, for efficiency), which makes the guides brittle, causing them to fail. The S62 doesn't suffer the heat. So, as long as you don't let the tensioner get weak, allowing it to flap about, the guides should be fine pretty indefinitely.IG: @limited.slip
Alpine White E90 M3 6MT
Alpine White 1 Series M
T̶i̶t̶a̶n̶i̶u̶m̶ S̶i̶l̶v̶e̶r̶ E̶3̶9̶ 5̶4̶0̶i̶ M̶-̶S̶p̶o̶r̶t̶ T̶o̶u̶r̶i̶n̶g̶ S̶6̶2̶ 6̶M̶T̶
