Weird glitches after SMG to Manual Swap
    Hello guys! I have weird glitches after coding my modules. When I press the clutch pedal my blinkers won’t engage, same with the headlights.
    I did my DME coding with ECUWORX but my rev lights won’t work
    I used NCS Expert to code the rest of the modules and everything worked without a problem.
    has any of you had the same glitches? Thanks!!!
    Sounds like you have a wiring issue. Have you removed the SMG control unit or left it plugged in?
      I did remove it after I sirve de car for a day to see everything was OK. Did I remove it too late?
