M3 Floor Mats NLA?
  • Gt4
    You should make carbon floor mats like the Porsche carbon mats. πŸ€”πŸ€”
    I will work on a rear seat delete option before Something that almost look like you could sit on but not.
  • SQ13
    If someone's looking for a more durable option than OEM floor mats:
  • Rokoz
    I'm crossing my fingers that the trunk mats come back into stock
  • Gt4
  • Cubieman
    Originally posted by I M Legend View Post
    I ordered a set and these are indeed embroidered:
    Maybe both "versions" are embroidered but that photo looks like the "new version". That's good to know what these latest offerings look like regardless.
    Differences I see:
    - Middle line is a darker shade of blue as opposed to purple on the factory mats
    - The "3" is shaped differently, like a different font is being used
    - There is a pronounced line around the logo, that why I think it looks like an iron on patch and not as nice as the OG mats.
  • I M Legend
    It says "embroidered" in the description on ECS, I wonder if they really are or if it's the cheeseball looking ones as of late where the it looks like an iron on patch.
    I bought 2 (black) sets when some thought they were going NLA and got the "shit" ones (IMO).
    If they are back to the as from factory look I'll want some.
  • PSUEng
    If you can phrase that such that the ECS rep can understand it and give a definitive answer I’d love to hear it. I don’t think their customer service people even work onsite after my last interaction with them.
  • Cubieman
    Looks like they're back in stock: https://www.ecstuning.com/Search/Sit...-11-0-029-231/
  • davidinnyc
    Originally posted by bimmerfan08 View Post
    What do the axes represent?
    y-axis is HP per wheel
    x-axis is revolutions per second
  • mcjreston
    I glued the Velcro circles back onto the mats after the backing started to deteriorate. It was three years ago and so far so good (approx. 14,000 miles of use since then.) See my post picture test in this Discussion on the adhesive I used. If you search for Loctite in this Discussion it will pop right up.
  • Slideways
    Technically speaking, that's contact adhesive. It just happens you can use it on rubber, but it is not rubber cement, which is something different.
    Thanks, corrected that in the post. I was just going off the label.
  • elbert
    Same yellow rubber cement they use for leather upholstery - https://www.amazon.com/Barge-All-Pur...0B5XDPLC&psc=1
  • Slideways
    Originally posted by dukeofchen View Post
    Haven't done it myself, but I seem to recall M539 using a drill brush attachment to scrape the disintegrating backing material off on one of his projects. Not sure what the ideal adhesive to use would be to bond the Velcro pad to the material underneath, I was thinking some kind of epoxy when I got around to give it a shot.
    Same yellow contact adhesive they use for leather upholstery - https://www.amazon.com/Barge-All-Purpose-Cement-Rubber-Leather/dp/B00B5XDPLC/ref=pd_lpo_sccl_2/147-1541134-0002268?pd_rd_w=O5CzI&content-id=amzn1.sym.4c8c52db-06f8-4e42-8e56-912796f2ea6c&pf_rd_p=4c8c52db-06f8-4e42-8e56-912796f2ea6c&pf_rd_r=FP22TW5FYD946N8KPKN5&pd_rd_wg =lDcCl&pd_rd_r=7db3c5f7-7431-45b9-97e7-ab57753e719a&pd_rd_i=B00B5XDPLC&psc=1
  • dukeofchen
    Interested in this as well. The thin fabric on the back of the mats disintegrated over time. The mats themselves are in great shape. I hot-glued the Velcro pads but they continue to separate from the mats. While purchasing new mats is an option, I suspect the same issue will arise in due time.
  • bimmerfan08
    Which tire valve stem caps are you running?
