I'm looking for LED bulbs for the high beams that fit behind the dust caps w/o modifications. Any recommendations?
LED bulbs for High Beam
LED's need a driver and heatsink that will take up space and make a perfect plug and play hard to find, at least for ones bright enough to do anything. These look promising but may not fit perfectly the way you want.Originally posted by I M Legend View Postno recommendations?
https://www.theretrofitsource.com/H7...2.0?quantity=1
Also the dust cap if you leave it on may cause premature failure of the LED due to heat. Just some things to consider.
Now that I think about it, does the high beam even have a cover? I thought it was just the HID that did.Last edited by Icecream; 11-21-2020, 10:45 AM.
Well considering they are claiming TWELVE THOUSAND lumens and a standard top of the line d2s HID bulb is 3500 lumens, I am gonna guess they are full of it and are junk.Originally posted by I M Legend View Post
Skip LED bulbs for headlights, especially cheap Chinese knockoffs. Without the proper projectors and drivers, you won't throw light very far. I run OSRAM Xenarc Cool Blue Boost bulbs, paired with Morimoto XB foglight assemblies for the E46.
TONs of clean, color corrected, light. Check out TheRetrofitSource.com
Fog lights: https://www.theretrofitsource.com/bm...E46?quantity=1
Edit: Skip the splitters and resistors, no need for the E46.Last edited by JayVee; 11-25-2020, 06:03 AM.
