Hi mates,
Today I've jacked the car up to inspect the exhaust because it had some small vibrations caused by the heat shield. Unfortunately, I saw another problem. The left outer cv joint had start leaking from the housings. As far as I remember, the turnermotorsport had a rebuilt kit but it's not offered anymore. So my options are to bring the shaft to a local company in Bulgaria for rebuild or to buy new ones. What's your experience with rebuilding them and what's the best option for new ones (OEM or there are better options)? Is there any good DIYs for the removal/installation process of the driveshafts? As far as I saw, I have to remove the spring and to lower the ARB and the exhaust? How hard is to remove the driveshaft from the wheel bearing flange and what tool would you recommend me?
Thanks
Thanks
