2005 M3 Vanos Refresh...NAM3 Forum...1st post. I just completed the Vanos rebuild and pump disk update from Beisan. My car has rather low mileage yet I had began to notice power surges around 2,800 rpm while in 2nd, 3rd and sometimes 4th gear. When the engine was cold, such issue was more pronounced and reduced slightly upon heating...a disturbing behavior none the less. I also had a spit and sputter on cold starting. Using the excellent guide from Raj I followed everything precisely and the outcome has been great. The components from Beisan are of premium quality and their shipment was quick. The surging is now gone as it is the cold start sputter. The car, to my surprise, has better throttle response. So if you have the same thing going on, refresh the Vanos and get back what performance was lost.
Nice job, I have all the parts from Beisan and the Lang bolts as well, I am quite nervous to be honest, valve adj. time as well.Originally posted by BMWGeek View Post2005 M3 Vanos Refresh...NAM3 Forum...1st post. I just completed the Vanos rebuild and pump disk update from Beisan. My car has rather low mileage yet I had began to notice power surges around 2,800 rpm while in 2nd, 3rd and sometimes 4th gear. When the engine was cold, such issue was more pronounced and reduced slightly upon heating...a disturbing behavior none the less. I also had a spit and sputter on cold starting. Using the excellent guide from Raj I followed everything precisely and the outcome has been great. The components from Beisan are of premium quality and their shipment was quick. The surging is now gone as it is the cold start sputter. The car, to my surprise, has better throttle response. So if you have the same thing going on, refresh the Vanos and get back what performance was lost.
Great to see your work did something to make the vehicle run better as well as the preventative measure.2004 Silbergrau Metallic 6MT
Cubieman...just make sure you all the tools, shop towels and cleaning and take your time. Honestly the estimate I’ve seen of 7 hours to do the vanos job seems like a 2 person estimate. The valve adjustment can indeed make a difference too if you have a big variance among the valve spacers. So doing all this work on the valves and vanos will go a long way.
I just went through the whole vanos overhaul with Beisan components. My engine is much quieter and the car drives a lot better after the overhaul and valve adjustment. I was getting getting an intermittent check engine light related to the vanos solenoid. Ended up also having a broken exhaust cam tab and broken chain rail guide.3 Photos'05 ///M3 Sparkling Graphite/Black 6MT
RAC Monolite RG4 I Bilstein B12 I Dixis Spirit I Beisan
How many miles on the car?Originally posted by TamuM3 View PostI just went through the whole vanos overhaul with Beisan components. My engine is much quieter and the car drives a lot better after the overhaul and valve adjustment. I was getting getting an intermittent check engine light related to the vanos solenoid. Ended up also having a broken exhaust cam tab and broken chain rail guide.2004 Silbergrau Metallic 6MT
