Here is a strange one.
I installed a back up camera on Friday. Had the battery disconnected the entire time. After the install the head unit and all the other gauges worked EXCEPT my speedometer and Mileage counter. The gas guage would also randomly increase and decrease by 1/4 tank cyclically.
I checked the 3 fuses for the Instrument cluster and cleared codes with PA Soft and INPA then reset the adaptations for the ecu. I also ran an instrument cluster test with INPA, I had full sweep with all the lights on all of the gauges.
No joy. There.
Just wondering what else needs to be checked? I’m going to try checking and clearing codes in the chassis modules today after work and resetting the adaptations there as well if I find any. I’ll also try pulling the rear wheels to check the speed sensors, I can’t imagine they just *poof* went bad though.
The car is an 11/2002 M3. I did a conversion to 6speed and coded the car myself. Everything was working before the battery was disconnected for the back up camera install. The car still runs and drives fine, my main concern is the ecu and instrument cluster not having the same milage and spitting out a fault that is more difficult to fix later.
-Steve
No joy. There.
-Steve
